Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
Reality-based computations (Non-Turing)
Researching a novel method to solve tasks, including NP
CapitanVeshdokiCapitanVeshdoki
Following Follow project
Liked Like project
Become a Hackaday.io member
Not a member? You should Sign Up.
Already have an account? Log In.
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
3 comments
0 followers
  • Description
  • Details
  • Files 1
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 3
View Gallery
60
3
0
0
Team (1)
  • CapitanVeshdokiCapitanVeshdoki
Join this project's team
MISC
researching project
Np tasks computations non-Turing
This project was created on 04/15/2019 and last updated 2 years ago.
Description
Originally it is for research paper, so I gonna publish everything "as is". Maybe I would convert it into web-page later, who knows :)
Details
Files
reality-based.pdf
Article about this project (theory, how to, thoughts e.t.c.)
Adobe Portable Document Format - 41.88 MB - 04/15/2019 at 15:17
Preview
Download
Log In/Sign up to comment
Sign up with Github
OR
agp.cooper wrote 08/12/2020 at 23:46 • point
Okay, you get the idea.
I suspect if your logic contained states (i.e flip flops) then it could be Turing but I am not an expert here. It a bit like the days of analog computers. There was a need when digital computers where a dream.
Anyway, I thought that it added a tool to my tool box. I have a number of "demo" like projects (a Turing machine being one of them). So the idea of converting a simple problem and an algorithm into a hardware demonstration is something worth keeping.
AlanX
agp.cooper wrote 08/12/2020 at 02:37 • point
Okay, perhaps I am wrong, but you appear to be describing a hardware greedy and/or iterative algorithm to solve your Sudoku problem. As such, your machine is still subject to the normal rules of algorithms (P!=NP etc) and your logic may not scale very well or even find a solution. Such is P!=NP. Unfortunately, Sudoku (the 9x9 case) is a know hard problem to solve.
Some thoughts:
* You can model many simple iterative algorithms with your approach, one example from my past was to model an underground ventilation system (a flow network) using "Kirchhoff's current law" as the iterative algorithm.
* Rather than a discrete hardware logic and finite state machine, you could a simple one-bit computer (as these work well in this domain).
* So there are many real world problem you can solve, that would make fun demonstration units. That is demonstrations units that don't use a microprocessor for control. The demonstration unit could feature the iterative algorithm and the real world problem it solves.
Any, best of luck with your project, regards AlanX
CapitanVeshdoki wrote 08/12/2020 at 13:29 • point
Sure, that's why this project was abandoned - it was a nice theory, however without practical applications it makes not much sense, especially being that hardware greedy (*possibly it can be done using FPGA as alternative*)
Someone told me, that it looks a lot like reservoir computation device, from my perspective it's more accurate, of course it's iterative, but algorithm as a sequence of instructions make sense only within the boundaries of blocks (e.g. numbers in case of sudoku), as you define rules using logic elements. It's hard to predict how it works in general and how blocks affect each other, no synchronization present, as well as no algorithm describes how to solve a task. It's funny that it works with all those ridiculous conditions.
As a non-Turing way to complete tasks it makes sense, is it fast or not - open for discussion. With my <suspicious> measurements it was impressive, but task wasn't horribly hard either.
Maybe at some point I will continue doing something with that concept, which was very curious. Can make a guess: there would be something to do with cryptography , )
Low cost and pocket sized equipment can be used to steal your credentials in WiFi networks that require login via a web pages
Project Owner Contributor
Phishing WiFi hotspots with captive portals
platis.solutionsplatis.solutions
Application framework for solving and sharing technical problems.
OneSolver.com
Grant PitelGrant Pitel
Grow Anything, Anywhere.
Steveland
David TroetschelDavid Troetschel
Presence awareness for the Internet of Things
Dowse
JaromilJaromil
Going up?
© 2021 Hackaday
Yes, delete it Cancel
You are about to report the project "Reality-based computations (Non-Turing)", please tell us the reason.
Send message
Remove Member
