Hardware - just stuff I had laying around, really...
- - Lego Egg-lathe, directly driven by a stepper
- - Lego linear motion stage, built from tracks of that Lego Boost robot
- - ESP8266
- - 2x A4988 drivers.
- - a proximity sensor for end-stop detection
Firmware - Arduino-based, aREST-based stepper motor driver, exposing a few operations:
- - Rotate egg by X degrees
- - Move pen to 0-100% position
- - Move pen by X%
- - initialize
- - pen up/down
Software
Blockly-based UI, in fact a modified MusicMaker example
- - a few custom blocks translated to the exposed REST methods
Yeah, yeah, I hear you:
- - The X stage is stupid, the pen should be moving parallel to the egg surface, otherwise it doesn't paint straight.
- - Egg coupling is shaky and doesn't "grab" well enough. Sure, it's built with Lego wheels!
- - Pen is shaky! It's mounted too far from the egg.
- - etc etc.
Well, sure! But if we'd want here the EggBot, we'd buy a EggBot! We're just having fun here :)
Impressive that you got the egg holding/spinning axis to work without dropping the egg, much less the two axes for the pen. Right on!
