BottomPlate.obj3D print file for main bottom base plate where the motors will be connected to.obj - 26.36 kB - 07/01/2019 at 17:23 |
ArduinoPlate.obj3D print file for back plate where the Arduino will be attached toobj - 17.26 kB - 07/01/2019 at 17:23 |
MotorBoardPlate.obj3D print file for side walls. The motor board will be attached to one of the walls.obj - 15.68 kB - 07/01/2019 at 17:23 |
DoorPlate.obj3D print file for front wall that can be opened up for access to the Arduino and other parts.obj - 4.83 kB - 07/01/2019 at 17:23 |
Motor Connectors - 12 Pack.stlCustom 3D printed motor connectorsStandard Tesselated Geometry - 65.71 kB - 05/11/2019 at 02:49 |
3D-printed-flipper.stlCustomer 3D printed spinner for the battle botsStandard Tesselated Geometry - 7.99 kB - 05/11/2019 at 02:48 |
