USB-C Gamepad Phone Case
A USB HID gamepad integrated into a phone case.
Public Chat
A forward-compatible gamepad using 3d printed cases and open source hardware. This controller is inspired by the many smartphone gamepads and and game-focused phones that have come and gone. New phones come out, more powerful hardware arrives, and the old products are left underspecced or incompatible.
WHY:
I want to play action/platformer games on my phone. The straw that broke the camel's back was "Prinny: Can I Really Be the Hero?" - I couldn't beat a boss because my fingers kept missing the intangible touchscreen controls. I want a gamepad that is compact to carry, comfortable to hold, and works with multiple phones.
HOW:
This version of the project uses USB-C to directly connect to the phone, and I plan on using an AVR chip to handle USB communication. Using a physical connection complicates phone compatibility but eliminates the battery and has better upgrade potential (battery bank for the phone, headphone jack, microSD slot, etc) through USB. The shell is 3d printed to adapt to multiple phones. Future versions can involve the community for improvements, support for more phones, and artwork.
INSPIRED BY (R.I.P.):
Xperia Play, OpenPandora., HTC Dream (G1), DS Lite, PSP
  • 1 × atmega32u4 Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • PCB routed, DRC passes
    Maave06/04/2019 at 02:03 0 comments
    Woohoo it's routed! And the DRC passes. I'll post source on Github soon and then start work on the 3d printed case. EDIT: source on github.
    Here's the evolution of the layout. I took a screenshot of the bottom half since that's the interesting part. It's fairly easy to move components and then autoroute with FreeRouting. I've shuffled a lot of components, changed the edge cuts, made the board slightly shorter and fatter, and shrunk the start/select buttons.
    v0: Bad. Components were roughly placed on the board. I accidentally had 10 mil track width so the USB-C connector wouldn't route.
    v1: It works. It routes now but it's ugly, the USB resistors are too close to the buttons, and there's very little room for future features.  The autorouter found some interesting routes near the USB connector that I wouldn't have thought of (I hope they work).
    v2: Better. The start/select buttons are in the wrong spot. I wanted the USB power and data lines shorter, and I didn't want them to cut across the tracks for the button contacts. Many of the components have been rotated - I selected the atmega, all the components underneath, and the header pins, then rotated. The flex area for the USB connector now goes down instead of sideways.
    v3: Good layout. I moved the start/select buttons (the smaller contacts) into the bottom corner, moved the components slightly, and reassigned some pins. There's breathing room now so I could easily route analog components (the pins on the left side of the ATMega).
    v4: Tweaks for the DRC. This is the last change for now. I adjusted the clearance on the USB-C pads (4 mil pad clearance instead of 6 mil) and barely moved the reset jumper. The autorouter ended up changing a lot of routes but it looks fine
  • Flex PCB progress - barely fits 2sq inches
    Maave05/27/2019 at 20:52 0 comments
    tl;dr look at the pictures
    Time for physical layout. I did some mockups on cardboard. Fitting into 2sq inches is a challenge. For now I'm going with a 2x1 vertical layout so that I can fit the shoulder buttons, but I could make it shorter and wider or even a 1.41x.141 square.
    I opened up a knockoff SNES controller to measure the silicone membrane. One minor issue is that the ABXY silicone won't fit with a 1-inch width layout but the D-pad will. For the first version I'll use a D-pad silicone on both sides. Later I'll look into smaller button sets like GBA, DS, and PSP. I'll also look into dome switches like those used in the 3DS, PS Vita, and Switch.
    This is a tight fit. I haven't routed anything yet, just roughly placed the components. The layout feels a little wasteful because I need to leave large open areas for the buttons. The D-pad pivots on a post so I can't put anything in the middle of the buttons (yet). The upside is that this leaves tons of room for silkscreen art and pad art.
    There are a number of changes that could save space
    -make it shorter and wider
    -shrink the start/select button contacts
    -use smaller components (currently 0805)
    -make the cuts as small as possible (check oshpark specs)
    -move the header pins that connects the 2 sides
    -adjust the flex PCB running to the L/R shoulder buttons
    -make the reset button a jumper (done)
    -swap ATMega 32u4 for the smaller 32u2 (questionable)
    -use the internal oscillator instead of an external crystal (highly questionable)
    The only USB-C male connector available in KiCad by default was this Molex 105444. I selected it for now to get the PCB going but this looks like a PITA. Please comment if you have recommendations.
  • Flex PCB brainstorming and schematic progress
    Maave05/21/2019 at 21:05 0 comments
    One my ideas was "controls on top", letting my palms rest on the sides of the phone. This layout has pros and cons, and after going over it with my fiance we decided against it. I still like the idea though. Here's a mockup that uses the flexible PCB to accommodate different size phones.
    The current plan is a smaller PCB that will make the phone more like a PSP. The two halves will be connected with a ribbon cable, flat flexible cable, or whatever. The prototype will probably use magnet wire soldered on.
    The prize in the flexible PCB contest is a voucher for 3 copies of 2 square inches of PCB from OSHpark. That'll only fit one side of my design. So I'll make this double sided - one side is the D-Pad, the other is the face buttons. Then I can make 1 complete controller and have another half spare. I can complete the spare half with an ATmega and experiment with it.
    Finally, here's my schematic progress. Gunna try routing the PCB now.
  • Background and prior attempts
    Maave05/21/2019 at 16:51 0 comments
    I've been spoiled by hardware controls, growing up with things like the GBA, Nintendo DS, and the HTC Dream / G1. The DS was a haven for homebrew and made a nice PDA before smartphones came around. My first cellphone was a used HTC Dream, with a well laid out keyboard that solidly flicked open, physical button on front, and a trackball that was fantastic for RDP/VNC.
    This idea started in 2014, playing emulators in the break room at work. By that time I had a newer phone - touchscreen only with a few capacitive buttons on the front. I hated it. I couldn't touch type, couldn't use terminal worth a damn, couldn't easily control a mouse over VNC, and couldn't play action games.
    The straw that broke the camel's back was "Prinny: Can I Really Be the Hero?" - I couldn't beat a boss because my fingers kept missing the intangible touchscreen controls. So I started mocking up a controller that would work with my phone.
    I brainstormed and sat on it for white a while. In 2017 I started working on physical versions. I made one test with an Arduino and HC-05 bluetooth module, and then went to the nrf51822 SoC bluetooth module. Progress halted for most of 2018 while I dealt with life stuff.
    Now it's 2019. Phone UIs and mobile game design have gotten better but playing action games is still putrid. I'm back, full force, ready to slam out a design in time for the Flexible PCB Contest.
View all 4 project logs
mbt28 wrote 05/29/2019 at 10:45 point
Hi,
Very nice project actually. How about adding usb otg chagring future? You need to add some caps or resistors, I dont know how it works with type-c but should very simple use normal 5V usb chargers.
A microcontroller which has I2S could be nice for the future implementations, since you can add a pair of front facing speakers with I2S audio amplifiers. Or maybe there is a way to use analog output from type-c with the same time with usb-2.0.
Maave wrote 05/29/2019 at 16:39 point
Yes, this definitely needs a USB port to charge the phone. I think my next 3 features will be
-charging port
-analog stick support
-3.5mm headphone jack
I believe that USB audio + USB gamepad is possible with the LUFA library.
