uStatusBoard
uStatusBoard is designed to be used as simple notifier with 4 NeoPixels to show the status changing the leds' color on the board.
The idea behind this project was to monitor the build status of different projects to keep track of them and fix those errors once the build is failing. So I gathered some components and started designing the board with the same dimensions as a Raspberry Pi Zero.
The good thing about the design is that is small enough to put it on my desktop and get notified when something happens on the process of Continuous Integration.
  • 1 × uStatusBoard
  • 1 × Wemos D1 Mini
  • 2 × 1x8 pin header
  • 4 × WS2812B
  • 4 × 100pf Capacitor
