The rubber gaskets
A project log for Global radiation monitoring network
The uRADMonitor is a plug-and-play, low power, self contained radiation monitoring device, connected to a centralised server component.
radu-motisanRadu Motisan 08/04/2014 at 07:390 Comments
As the uRADMonitor Model A is intended as a environmental radiation surveillance tool, that should be run outdoors, we’ve designed rubber gaskets for the aluminium enclosures, to make sure rain will not get in to damage the components.
autocad_rubber_gaskets_uradmonitor
Now finally we saw the first components getting out of their factories and wanted to share with all of you. Here are the first rubber gaskets tested. They fit perfectly, offering protection level up to IP65.
rubber-gasket-results-small
The company in charge of manufacturing the cases and the rubber gaskets is the Shenzen Superbat Electronics Limited, checkout their portfolio for some great products. We’ve been impressed by their professionalism and their will to help us. Great guys!
