Answers.
11/05/2016 at 11:19 • 0 commentsImage 1:
- Row 1: None
- Row 2: 'B'
- Row 3: 'A'
- Row 4: 'D'
- Row 5: 'C'
- Row 6: 11
- Row 7: 5
- Row 8: 16
rotors='III IV V' # from image rows containing display settings
reflector='B'
ring_settings='11 5 16'
plugboard_settings='HA CK DY'
set_display("ADC")Decrypted message:
'OIIOIOOOOIIIOIOOOIIIOIOOOIIIOOOOOIIIOOIIOOIIIOIOOOIOIIIIOOIOIIIIOIIOOIOOOIIIOOIOOIIOIOOIOIIIOIIOOIIOOIOIOOIOIIIOOIIOOIIIOIIOIIIIOIIOIIIIOIIOOIIIOIIOIIOOOIIOOIOIOOIOIIIOOIIOOOIIOIIOIIIIOIIOIIOIOOIOIIIIOIIOIIIIOIIIOOOOOIIOOIOIOIIOIIIOOOIIIIIIOIIOIOOIOIIOOIOOOOIIIIOIOOIIOOOOOIOOOOIOOOIIOIIOOIIIOOOOOIIOOIOIOOIIOOIOOIOIIOOOOIIIOIIIOIIOIIOIOIIOOOOIOIOOOOOIOIOIOOOOOIOOIIIIOIOIIOOIOOIIOOOIOIOIOOIOOIIOIOIOOIOOIIOIOIIOIOOIOOIIOOOIOIOOIOIIOIOOIIOIOIOIOIIIOIIIOIOOOIIIIOOIOIOIOOIIOIOIOIOOOIOOOOOI'
'O' = 0
'I' = 1
URL:
https://drive.google.com/open?id=0B6pe2XwmaAPOY1RjMi1KMWtySTA
Image 2:
- Col 1: 'C'
- Col 2: 'D'
- Col 3: 11
- Col 4: 'A'
- Col 5: 6
- Col 6: 'C'
- Col 7: 16
- Col 8: None
rotors='II IV VI' # from image colss containing display settings
reflector='C'
ring_settings='11 6 16'
set_display("ADC")Decrypted Message:
'IOOIOIIIIOOOIOIIIOOOIOIIIOOOIIIIIOOOIIOOIIOOOIOIIIOIOOOOIIOIOOOOIOOIIOIIIOOOIIOIIOOIOIIOIOOOIOOIIOOIIOIOIIOIOOOIIOOIIOOOIOOIOOOOIOOIOOOOIOOIIOOOIOOIOOIIIOOIIOIOIIOIOOOIIOOIIIOOIOOIOOOOIOOIOOIOIIOIOOOOIOOIOOOOIOOOIIIIIOOIIOIOIOOIOOOIIIOOOOOOIOOIOIIOIOOIIOIIIIOOOOIOIIOOIIIIIOIIIIOIIIOOIOOIIOOOIIIIIOOIIOIOIIOOIIOIIOIOOIIIIOOOIOOOIOOIOOIOIOOIIIIOIOIIIIIOIOIOIIIIIOIIOOOOIOOIIOIOIOOIOOIIIOIIIIOIIOIIIOOOIOOIIOIIIIOOIIIOIOOOIIIIIIOOIIIIIOIOOIIIIIOOIIIOIOIOOIOIIIOOIIOIIOIOIOIIIOIOOIIIIOIIOOIO'
'O' = 1
'I' = 0
URL:
https://drive.google.com/open?id=0B6pe2XwmaAPOelBGd1p0X1Z2TXM
Hint 4
11/05/2016 at 01:20 • 0 commentsmachine.set_display("image specific") msg = machine.process_text(msg, replace_char='X') url_str = '' for i in msg: if i == 'O': url_str += 'you pick' if i == 'I': url_str += 'you pick' url = text_from_bits(url_str) print url
Hint 3
11/04/2016 at 00:12 • 0 commentsmsg = '' for i in message: if i != '\x00': msg += i from enigma.machine import EnigmaMachine machine = EnigmaMachine.from_key_sheet(rotors='image specific', reflector='image specific', ring_settings='image specific', plugboard_settings='obvious')
Hint 2
11/02/2016 at 23:42 • 0 comments... bin_message += '0' if g & 0b1 == 1: bin_message += '1' else: bin_message += '0' if b & 0b1 == 1: bin_message += '1' else: bin_message += '0' import binascii # You can use an online binary to ascii converter, or these functions. # Such as this: http://www.rapidtables.com/convert/number/binary-to-ascii.htm # http://stackoverflow.com/questions/7396849/convert-binary-to-ascii-and-vice-versa def text_from_bits(bits, encoding='utf-8', errors='surrogatepass'): n = int(bits, 2) return int2bytes(n).decode(encoding, errors) def int2bytes(integer): hex_string = '%x' % integer n = len(hex_string) return binascii.unhexlify(hex_string.zfill(n + (n & 1))) message = text_from_bits(bin_message)
Hint 1
11/02/2016 at 01:11 • 0 commentsfrom PIL import Image img = Image.open('image_with_crypt.png') rgb_img = img.convert('RGB') width, height = rgb_img.size bin_message = '' for row in range(height): for col in range(width): r, g, b = rgb_img.getpixel((col, row)) if r & 0b1 == 1: bin_message += '1' else: ...
