Featuresenlosure and prototyping board:
- milled cab rail enclosure (6 modules)
- for EN50022 DIN rails
- prototyping plate - fits perfectely in the enclosure
- 1x 2-pin terminal block for power supply
- 1x 3-pin terminal blocks for general purpose
- 2x 2-pin terminal blocks for general purpose
- 2X20 pin socket for the Raspberry Pi
- Breadboard area
- Openings for Audio, HDMI and Mico-USB on right side
- pcb contains a layout for a voltage 5V/1.7A voltage regulator
- removable protections for terminals
- transparent lid or grey lid
- dimensions: 105mm x 90mm x 65,3mm (W x H x D)
Rob Crouthamel
YC-L
