The watch is slick and cool looking. The casing is made from plastic, but it doesn't look 3D printed. It isn't water proof, since it has the micro sd card slot, the USB-C charging port and a few other stuff open on the case.
2
Programming
Supports the Arduino IDE, but you can program it using the command line too. The procedure is the same as for regular ESP32, that was the platform i was using for programming it.
3
Specifications
ESP32 Dual Core micro processor (WiFi and Bluetooth capable)
Capacitive touch sensing under TFT screen
Micro SD card slot
Buzzer RTC module
AXP202 power system management IC
BMA423 accelerometer
You have backside slots that allow third-party and first party accessory modules like GPS, LTE, LoRa and etc
