1Design
The watch is slick and cool looking. The casing is made from plastic, but it doesn't look 3D printed. It isn't water proof, since it has the micro sd card slot, the USB-C charging port and a few other stuff open on the case.
2Programming
Supports the Arduino IDE, but you can program it using the command line too. The procedure is the same as for regular ESP32, that was the platform i was using for programming it.
3Specifications
ESP32 Dual Core micro processor (WiFi and Bluetooth capable)
Capacitive touch sensing under TFT screen
Micro SD card slot
Buzzer
RTC moduleAXP202 power system management IC
BMA423 accelerometer
You have backside slots that allow third-party and first party accessory modules like GPS, LTE, LoRa and etc
4Battery
Battery life is good, the watch has a 180mAh flat lithium battery. The battery is standard, so it can be swapped.
5Sorry
Sorry, but I couldn't add pictures because my phone is broken.
