LilyGO TTGO Watch
A smartwatch that is made by LilyGO.
In this project i will review the LilyGO TTGO Watch.
  • 1 × LilyGO TTGO T-Watch
  • 1
    Design
    The watch is slick and cool looking. The casing is made from plastic, but it doesn't look 3D printed. It isn't water proof, since it has the micro sd card slot, the USB-C charging port and a few other stuff open on the case.
  • 2
    Programming
    Supports the Arduino IDE, but you can program it using the command line too. The procedure is the same as for regular ESP32, that was the platform i was using for programming it.
  • 3
    Specifications
    ESP32 Dual Core micro processor (WiFi and Bluetooth capable)
    Capacitive touch sensing under TFT screen
    Micro SD card slot
    Buzzer
    RTC module
    AXP202 power system management IC
    BMA423 accelerometer
    You have backside slots that allow third-party and first party accessory modules like GPS, LTE, LoRa and etc
View all 5 instructions
