Eyelid Track.step
3D printed parts for the eyelids to open and close. The eyelid is attached to the small slider, and the track is glued into the inside of the outer eye part.
step - 70.99 kB - 04/25/2020 at 17:48
Download
Wheatly_Sound_Slave.ino
This code takes input from the Master Arduino and gives data to the adafruit soundboard.
- 1.29 kB - 06/14/2017 at 12:24
Download
Wheatly_Motor_Slave.ino
This code takes input from the Master Arduino and writes data to the motors. This also reads data from the potentiometer.
- 4.20 kB - 06/14/2017 at 12:26
Download
Wheatly_Master_Ardunio.ino
This code takes input from the remote receiver and sends data to the other two arduinos over I2C.
- 19.02 kB - 02/25/2017 at 13:48
Download
completed frame.123dx
A design of the frame. The mechanical workings are not complete.
123dx - 2.31 MB - 11/23/2016 at 20:16
Download
TAD design.123dx
Autodesk 123D design of the track attachment device. STL downloads are available on thiniverse: http://www.thingiverse.com/thing:1913433
123dx - 921.27 kB - 11/23/2016 at 20:15
Download
