Z axis mount is both machinable and printable. Because the goal is to have a heated chamber print in a high temp plastic like ABS or better PC, PEEK, Ultem etc. Depending on mounting it is possible this mount will not have any direct heat within the chamber. More on that later.
Potential mounting solution. Still searching for a 6mm ID GT2 belt.
