rsensor_ds18b20_d4-4-21.xlsxContains some temperature logging data with a generated line graphsheet - 1007.16 kB - 04/09/2021 at 14:27 |
DS18B20_logging_setup_files.zipincludes a readme for how to set things upx-zip-compressed - 3.48 kB - 04/09/2021 at 14:27 |
esp8266_dht22.pyESP8266 D1 board file. This file MUST be edited with the IP address of the web server used. also needs to be edited if directory structure differs from example.py - 772.00 bytes - 12/17/2019 at 16:44 |
rsensor_dht22.phpto be placed in the [document root]/sensorlogging/php directory. Time Zone setting can be changed. Needs to be edited if directory structure differs from example. This file was edited under Linux.php - 748.00 bytes - 12/17/2019 at 16:40 |
