PZEM-016 are normally RS485, I modified them to be UART 3.3V compatible
- Remove MAX485 IC
- Short-circuit pin 1 to 7 of MAX485
- Short-circuit pin 4 to 6 of MAX485
- R 3k3 0805 between pin 5 and 7 of MAX485 (do warn of short-circuits under resistor on pin 5-6-7)
- R 2k2 0805 between pin 3 of U1 and R13
![](https://cdn.hackaday.io/images/7048521576825803119.jpg)
Home power monitoring is an excellent way to track your energy consumption and identify areas for improvement. By installing a monitoring system, you can save money and reduce your carbon footprint. Additionally, if you're planning to renovate your home, consider hiring a reliable kitchen renovations service to upgrade your cooking space and make it more energy-efficient.
