a few years later
06/15/2022 at 21:05 • 0 commentsThe component to wire this to the house electric system are slowly being gathered.
I top off the battery every few months, but the leakage current seems minimal. Only a loaded test will tell how much capacity is still usable from the battery.
I also need to find a way to power this with renewable energy. The water wheel seems to be the best options in terms of cost benefit and complexity, but finding a copper line to cover the 200-300 meters between the house and the water stream is not easy when you have no budget. -
The reversing of the UPS
01/01/2020 at 19:25 • 0 commentsThis should have been one of the first log... better late than never.
During this phase a learned a bit about how that UPS worked, Especially how the old battery where wired internally.
here is a look of it after the little modification. I added the cable on the right that go to the back of the UPS where there screwed to a terminal. Ready to connect the external battery.
Originally the four cable on the left went to theses two fuse pannel (for lack of a better decritpion) and from there where wired 4 pack of batterys. each pack contained 24 battery wired in series for a total of 288V
I believe that there pack where put half in serie and half in parallel and that a -288V was created with the two 288V pack put in serie . Then the juice went to the internal circuitry. from there i guess that a H bridge created the Sinus but this is only an educated guess as i didnt dive deeply into the circuitry...
It's Alive
01/01/2020 at 19:07 • 0 comments![]()
after connecting all the battery correctly, dodging all the short circuit i finally managed to fire up the system and guess what : It work !
the UPS accepted the new battery withouth complaining and after some poking around it even allowed to reprogram their capacity. The UPS can now deliver up to 40kW of power to anthing that is attached to it (the modest desk lamp you see on top of it for now) it would take up to 2 and half hours to empty the battery at full power but for the average consuption I expect more like 10 days of autonomy before we run out of power.
Next step, Solar panel, wind mill and even maybe water wheel to charge the system
The big short
12/30/2019 at 11:15 • 0 commentsEver wonder what a big oopsie can do ? hopefully only one battery was rendered unusable and I had 8 spare to switch them.
The incident lasted around 3-4 secondes but it was enough to vaporize a screw and melt the lead of the battery. the other battery dont seem to be affected.
Hit the bench
12/30/2019 at 11:12 • 0 commentsI just had to place each of the 96 battery on the dry floor. each of them weight 35 kg and god my leg still hurt.
Dry floor
12/30/2019 at 11:11 • 0 commentsI dont have much experience with brick and mortar but after some try it worked
On the next picture you can see the old clay floor that get flooded every now and then. I just dropped a few brick pillar to hold the palette in place dont worry the brick ended up well alligned
and now finnished with the back of the UPS on the right
Flood
12/26/2019 at 12:33 • 0 commentsAs we dismantled out old battery rack we discovered that water flooded around a centimeter under the pallet. Its a (very) old basement and we discovered that during winter water infiltrate it and let the floor wet. This is a problem since the wood rot in such humid environement and we have to adapt our plan.
We are now forced to make some brick pillar to create a dry floor for the battery. preferably in a configuration such that we can connect all the battery longitudinally and make best us of the 4 horizontal connexion we can make.
(I may have to forget to mention that the UPS need 4 battery pack at 288 V each this leave out 8 battery out of the 104 and 96 will be really usefull)
The First attempt
12/26/2019 at 12:02 • 0 commentsAt first we had to prepare a nice rack to load up the battery, As you may see on the picture its made out of EuroPalette that you can get for free or pay 20 $ a piece depend where you ask.
Unfortunatelly, we reallised later that the battery where bonded by a thick copper plate with two hole and we had to screw them between the battery terminal. Or we had around a hundred piece that allow us to bond them in lenght but only four that bound them laterally so we had to rework the battery layout
Nathann
