Otter-Iron - TS100 USB-PD hardware mod
Replacement PCB for TS100, adds USB-C PD to every hackers favourite tool!
Hardware is finished and working, software V0.1 is released!
Features:
- You can solder!
- Tmperature can be adjusted via buttons
- USB-PD requests highest voltage
- Display shows set-temperature, temperature and input-voltage
- Designed by an Otter *chirps* :3
I
Ordering and assmebly instructions
The BOM can be found at KiCAD/production/kitspace_bom.csv. Most parts are generic parts, which can be ordered and assembled regulary. However the display and tip-holders need special attention. The PCB has to be ordered with a thickness of 1mm (1.6mm works too, but 1mm has a better fit).
Tip-Holders / mechanical parts
The original tip-holders are custom made thus it is not possible to buy them, if you already have a TS100 it is highly recommended to recycle those. They can be unscrewed, cut to size and soldered/screwed onto the Otter-Iron. This is the preferred option!
If you don't own a TS100 you can buy one from miniware (price ranges from 35$ to 45$) and harvest the parts (as well as the casing and tip!).
You can also buy the littlefuse fuseholders mentioned in the BOM. Those however have a very bad fit, you have to bend them and add a little solder notch, otherwise you may destroy your tips. In addition to this solution you also need to buy a spare case+tip which is ~25-35$, this is the least preferred option.
Display
The display can be bought from LCSC or Aliexpress, I haven't found it at Mouser yet (Maybe its this display?). It is the last part to be assembled, it is soldered on the back of the pcb facing the PCB and the tip-end.
Flashing
To flash the Otter-Iron short the DFU-jumper shown in the image below while plugging it into your computer. This will put the iron into DFU mode allowing you to flash it via DFU/USB. Run this command to flash the downloaded binary.
$ dfu-util -a 0 -s 0x08000000:leave -D firmware.bin
Video
Video (clickme)
Images
Todo software
 - [x] Write a better regulation
 - [ ] Current measurement
 - [x] Store last setpoint
 - [ ] Better Fonts/UI
 - [ ] PD-Profile cycling
Todo Hardware
Todo next hardware revision:
 - [ ] Add barrel jack
 - [ ] Add grounding solution
  • non-volatile memory update
    Jana Marie01/19/2020 at 22:23 0 comments
    With this release your TS100 will remember it's set-point, won't overshoot anymore, shows a better DFU-screen and get a nice power-showing-bar! Temperature control is now much more advanced... Much less crappy at least. :3
    Firmware Download: https://github.com/Jan--Henrik/Otter-Iron/releases/tag/v0.3
  • Seccond release!
    Jana Marie01/03/2020 at 18:19 0 comments
    I just released firmware v0.2:
    This release adds a dfu-bootloader (to enter press both buttons while plugging in, display will show "dfu") and a cascade controller (Two-step controller + PID, faster heating and less overshoot). Firmware is still shitty af ^^
    dfu-utils usage:
View all 2 project logs
