Hackaday.io Hackaday.io
Sign up Log in
Epoxy NFC reader
ISO-14443 reader in epoxy resin
pavel-zhovnerPavel Zhovner
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
2k views
0 comments
10 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
2k
0
10
9
Team (1)
  • pavel-zhovnerPavel Zhovner
Join this project's team
completed project
hardware
This project was created on 03/07/2020 and last updated 6 years ago.
Description
I'm tired of scratchy PCBs and break away wires and pins, so I decided to fill it with epoxy resin to make it monolithic :) I take a popular PN532 module that used a lot in Arduino and Rapsberry NFC projects. PN532 connected overt UART to USB adapter CP2102.
Details
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Magnetic Modules: the screw terminal based, magnetic mounted experiment kit. Made from affordable and broadly available parts.
Project Owner Contributor
MagnaMods
jeroen-brinkmanJeroen Brinkman
Dead laptops have USB Bluetooth that can be used again.
PC Bluetooth Reconditioning
stanislas-bertrandStanislas Bertrand
Small USB to Serial programmer module, with Type C port and having compatibility with Arduino micro-controller.
Arduino serial Programmer CH340N
lithium-ionLithium ION
This is the GOD version of this microcontroller, adds up a lot of features. Sensor, modules and displays can be directly plugged in.
DIY Arduino UNO PRO Version
sagar-001Sagar 001
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Epoxy NFC reader", please tell us the reason.
Send message
Remove Member
