The circuit needs to be very robust. Kids can plug in any small DC motors
I've built this circuit before using a motor driver and an Arduino. However, it's over kill for young creators . So I want to combine a bluetooth with a driver in one board (see pictures).
Whats the best bluetooth module to use?
And which driver chip should I use?
Input
  •  Voltage range should be 3 to 9 volts
  • Speaker Push Terminals. Color coded
Output 1, 2
  •  3-6 volt output Push terminals.  max 800 mA
Output 3
  •  led  3 volt max 30mA connection indicator
basic Polarity safety electrical on both ends.  Any suggestions
power indicator
Built in Bluetooth antenna.
