Adobe Portable Document Format - 73.21 kB - 03/31/2020 at 22:24 |
Adobe Portable Document Format - 79.73 kB - 03/31/2020 at 20:07 |
Adobe Portable Document Format - 69.47 kB - 03/31/2020 at 20:07 |
Adobe Portable Document Format - 69.11 kB - 03/31/2020 at 20:07 |
Adobe Portable Document Format - 58.28 kB - 03/31/2020 at 20:07 |
minimoog - facade.svgThe face plate with all markings, functions, holes for pots and switches.svg+xml - 204.16 kB - 03/20/2020 at 14:00 |
minimoog - panneau lateral.svgThe lateral plate with LFO, pitchbend and mod wheel.Hot-bent. svg+xml - 57.65 kB - 03/20/2020 at 14:00 |
minimoog - capot arrière inferieur.svgThe panel that hides the inside and on which plugs are mounted. Hot bent.svg+xml - 37.50 kB - 03/20/2020 at 14:00 |
minimoog - capot arrière supérieur.svgThe rear side of the front panel.svg+xml - 5.29 kB - 03/20/2020 at 14:00 |
