aquametric-electron3.inoLatest Sensor Firmwareino - 7.50 kB - 10/05/2020 at 02:51 |
Aquametric_2020-10-04_22-49-33.jsonEasyEDA Schematic FileJavaScript Object Notation (JSON) - 31.93 kB - 10/05/2020 at 02:50 |
SensorBody.stl(Old Sensor Version) The batteries and microcontroller live here. The wires that run outside of the sensor are to be potted with epoxy.Standard Tesselated Geometry - 619.81 kB - 04/10/2020 at 22:57 |
Lid.stl(Old Sensor Version) The ultrasonic sensor is epoxied into the hole.Standard Tesselated Geometry - 180.65 kB - 04/10/2020 at 22:57 |
AntennaHousing.stl(Old Sensor Version) This is epoxied to the main sensor body. The pcb antenna is attached on the inside.Standard Tesselated Geometry - 194.52 kB - 04/10/2020 at 22:59 |
PoleCollet.stl(Old Sensor Version) This holds the device on the aluminium extrusion.Standard Tesselated Geometry - 47.45 kB - 04/10/2020 at 22:59 |
