MadEyes
Camera Server with supporting 5 POE cameras, USB storage, internal power supplies and light indication of motion detection.
Public Chat
In the process of building an IP Camera server. The build so far contains a clear plexiglass housing, an ATX power supply, an 8 port switch, 1 5T USB drive with room for a second, an odroid with motionEye, a raspberry pi with raspbian and node red, an 8x8 RGB Square and cable management.
The short video shows the system in response to motion detection.
RJ45 KEYSTONE PLATE POE.stl
Standard Tesselated Geometry - 262.97 kB - 05/03/2020 at 22:31
Download
ATX PSU BACK PLATE.stl
Standard Tesselated Geometry - 113.56 kB - 05/03/2020 at 22:23
Download
  • 1 × Odroid XU4
  • 1 × Raspberry PI
  • 1 × 5T USB Drive
  • 1 × ATX Power Supply
  • 1 × 8 Port Switch
View all 9 components
  • Front Panel
    blacklyquid05/06/2020 at 19:11 0 comments
    Working on finishing up some of the front panel details.  Attached 8x8 RGB panel, connected the switch and a little bead board so the front panel can easily be removed by unplugging cables.
    There is a DS18B20 sensor that is not currently working with node-red, will be shortly.
View project log
Robin wrote 05/02/2020 at 15:26 point
What are the lead screws doing?
blacklyquid wrote 05/03/2020 at 17:27 point
The lead screws pull and push holders for the usb hard drives, supports 2 but only 1 is currently being used. Using a  screw driver you can push in to disengage the little gears, then turn to clamp the drive into place.
