Front Panel
05/06/2020 at 19:11 • 0 commentsWorking on finishing up some of the front panel details. Attached 8x8 RGB panel, connected the switch and a little bead board so the front panel can easily be removed by unplugging cables.
There is a DS18B20 sensor that is not currently working with node-red, will be shortly.
