Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
Lichee Zero u-boot Getting Started!
What to do with a little SoC and an SD-card? Let's start with a little bit of u-boot!
NYH-workshopNYH-workshop
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.6k views
0 comments
2 followers
  • Description
  • Details
  • Files 0
  • Components 8
    • View all
  • Logs 0
  • Instructions 8
    • View all
  • Discussion 0
View Gallery
1.6k
0
2
1
Team (1)
  • NYH-workshopNYH-workshop
Join this project's team
  • How to build uart0-helloworld-sdboot
  • simple U-boot tutorial
  • How to add copy and paste from virtual machine to
  • Allwinner FEL/FES/NAND dumping
MISC
ongoing project
allwinner v3s lichee zero
This project was created on 05/04/2020 and last updated 2 years ago.
Description
This page is a small tutorial on how to get started on u-boot on Lichee Zero.
Note: This is not a simple and straightforward tutorial - expect failures and more of it as you go. You need patience and a lot of time to work with it.
Components
  • 1 × Sipeed Lichee Zero
  • 1 × VirtualBox
  • 1 × Any Linux ISO - I'm using Lubuntu here as an example
  • 1 × USB->Serial converter cable
  • 1 × Breadboard Electronic Components / Misc. Electronic Components
View all 8 components
Build Instructions
Collapse
  • 1
    First thing first - set up Linux Environment in Virtual Box
    1. Install Virtual Box.
    2. Download a Linux ISO - preferably small size like Lubuntu.
    3. Once you have Virtual Box installed, load up the Linux ISO and install it in the virtual HDD (follow the directions provided).
    4. When you have the Linux all installed - go to the Terminal.
  • 2
    Enable cut and paste to/from host machine to virtual Linux
    On the Virtual Box manager:
    Make sure these are selected in the settings.
    Then, do the following:
    [Source: https://askubuntu.com/questions/63420/how-to-fix-virtualboxs-copy-and-paste-to-host-machine]
    1. Start the virtual machine
    2. Click Devices menu
    3. Select Insert Guest Additions CD image
    4. Change to the directory where your CD-ROM drive is mounted (typically /media/<user>/VBOXADDITIONS_x.x.x/)
    5. Go back to terminal, then key in "sudo sh ./VBoxLinuxAdditions.run"
    6. Reboot the virtual machine!
    Thanks to the author for that directions in the source provided.
  • 3
    Install dependencies and supporting software and drivers
    You need these dependencies. Enter these in terminal:
    1. sudo apt-get install build-essential
    2. sudo apt-get install libusb-dev
    3. sudo apt-get install build-essential pkg-config
    4. sudo apt-get install libncurses5-dev libncursesw5-dev
    5. sudo apt-get install gcc-arm*
    6. sudo apt-get install python
    References:
    1. https://askubuntu.com/questions/161104/how-do-i-install-make
    2. https://github.com/nealey/hdjd/issues/12, https://stackoverflow.com/questions/4853389/how-to-install-libusb-in-ubuntu
    3. https://whycan.cn/t_539.html
    4. https://www.cyberciti.biz/faq/linux-error-cursesh-no-such-file-directory/
    5. https://stackoverflow.com/questions/14180185/gcc-arm-linux-gnueabi-command-not-found
View all 8 instructions
Log In/Sign up to comment
Sign up with Github
OR
a hardware sampler based on the raspberry pi running bare metal (so no Linux)
Project Owner Contributor
openSampler
Nick VerlindenNick Verlinden
Parallax Propeller plays our classic MIDI tunes from the SD-Card!
Propeller Weekender: Andy Schenk's Music Obj.!
Cassette tape replacement for old 8-bit machines
ArduiTape
sad_kensad_ken
A quick upgrade of my venerable 20GB iPod from 2005, replacing the spinning hard drive with an SD card reader.
iPod (4th gen) with 128GB SD Storage
re4matre4mat
Going up?
© 2022 Hackaday
Yes, delete it Cancel
You are about to report the project "Lichee Zero u-boot Getting Started!", please tell us the reason.
Send message
Remove Member
