NEW RELEASE with improved hardware and software available here: https://reppanel.com
Supports wireless connection or wired via UART/PanelDue port.
An open source alternative to the PanelDue.
* Cheap (~18€ display + 7€ ESP32)
* Beautifully dark
* Compact and easy to use
* Support for most operations required to set up a 3D print
* Wireless connection - portable with power bar
* PanelDue-port/UART connection
Features
Since RepPanel boots in ~1 second you can start setting up your printer in no time and with no additional hardware. No need to get the laptop and log in to DuetWebControl. No need to get mad over using WebControl in your smartphones browser.
Components
1×
ESP32
Dev Kit of some kind
1×
TFT Display with touch supported by LittleVGL for ESP32
I recommend https://www.buydisplay.com/lcd-3-5-inch-320x480-tft-display-module-optl-touch-screen-w-breakout-board with capacitive touch display
Cool, I really like your sharing. Thank you for your contribution!
