DIY watch that is open source and easy to build.
* Have WiFi and Bluetooth.
* 1.7 inch IPS LCD display, bright enough in daylight(non-touch).
* 44mm in size and 12mm in depth, fits on any wrist size.
* Dock that helps you to charge the watch and program it easily
* Have low power mode that helps the watch to last for days.
* 2 hardware buttons, both are customizable in the firmware.
* Vibration Wide-range of changeable watch bands.
* 6 pin docking connector with serial and power.
* Easy to build and modify the software.
* Update the software using a mobile or PC using OTA.
Please use this guide to build one https://www.instructables.com/MutantW-V2-DIY-ESP32-S3-Smartwatch-That-You-Can-We/
You can order the PCBs as well as the 3D parts from PCBWay with fair price, use the link below
https://www.pcbway.com/setinvite.aspx?inviteid=390855
If you have any question or suggestion
* https://discord.gg/RbYJhYjH3Z
* https://gitlab.com/mutantC
