ResQ Open Source Search and Rescue Tool
Small hardware package to detect people by using their existing cell phone signature
This open source project investigates using AP beacon packet sniffing to locate people such as lost hikers, campers and even poachers in game preserves. This works anywhere- as long as wifi is enabled on the targets phone. The hardware detects the beacon frames from their cellular phone, records the GPS coordinates for use later. 2 flavors are made: one hand-held portable and the other airborne carried by plane or drone.
I was inspired by the constant stream of search and rescue operations on the television show "North Woods Law". Each week they struggled to find lost people in the remote/rugged areas of Maine U.S.A. These areas often have no cellular service but in almost every case the target people had cellphones on them and working. As I live in Canada- we have a surplus of these situations in our vast wilderness as well.  I theorized I could use an external 2.4GHz antenna to receive the AP beacon frames from those phones ad capture that data.
This hardware can be embedded in to any very small drone or RC aircraft. It can also be attached to existing manned aircraft already participating in the search.
Using small drone aircraft (like the Nano Talon I use here) gives all the advantages such as flight condition tolerance, height, terrain, time of day etc that drones have over manned aircraft. They can also be sent on the full way-point mission without human intervention and tracked live from any ground station.
I started this build in 2018 and have proven out the Nano Talon airrframe to be a very worthy commercial candidate with good payload and HUGE flight times while operating fully autonomously. The Nano Talon breaks down small for easy transport/storage.
So far I am using the Wedmos D1 mini PRO with an external antenna (YAGI or Rubber duck) to receive the beacon frames, log them to SD Card with RSSI values (adds more precise direction finding if you fly a grid pattern) to review the MAC address list as well as plot with Google Earth/maps. I can easily transmit this via LORA or NRF module to the ground instantly as well. This will be logged as a separate version of the hardware.
I will update this and post the videos as we move forward with publishing (this will take me some time to document properly)
Stay tuned.
  • Air Unit Enclosure Added
    Eric Wiiliama day ago 0 comments
    I needed to get the air unit sorted for the airborne hardware (the ground unit is a lot easier/simpler) so I decided to sort out the enclosure and test fit it this weekend.
    Here is the first test version inside the payload bay of the Nano Talon:
    The CAD file originated from Thingiverse and the links are in my GitHub repo.  The Thingiverse customizer seems to be broken so I downloaded OpenScad and tried my own dimensions:
    I was pretty amazed at how easy OpenScad was to work with (small files too). Opened up CURA and sliced/printed on my i3 Mega with no issues
    All this will be included in the overview video coming soon.  I may need to resize the enclosure once I test the GPS unit (I really want try try to keep the GPS inside the case but probably need to run it to the top of the aircraft).
    Progress.
  • Air Unit Testing
    Eric Wiiliam4 days ago 0 comments
    Since I will be doing the ground YAGI and an air-unit version I spent some time testing the UAV to carry the payload.
    The Nano Talon is still my aircraft of choice here and I've finally made some time to properly finish setting up the autopilot and antonymous modes.  Last night I took a quick tuning flight with the air unit in the belly storage (no ground communication from the ESP-82666 though).
    Setup video: https://photos.app.goo.gl/ZQPJnyyMeQhym54D9
    The aircraft is broadcasting two telemetry downlinks in this test. One is my ~900MHZ control link which has full telemetry of all aircraft signals back to my radio and a second which allows monitoring and control via 433MHZ.  Both worked perfectly.  You can see the thunder storms building around me as I performed an auto trim cycle which centers the control surfaces for my new payload in flight.
    https://photos.app.goo.gl/KsjNefCDpH9coqWx6
    Full DVR video: https://photos.app.goo.gl/KsjNefCDpH9coqWx6
    Ultimately my video downlink failed and I have ordered a new diversity receiver module for my goggles as well as dropped the power output down on the VTX as it has been overheating in this >34C heat lately.  The new video receiver will be here next week and should work better in all conditions since it will now "stitch" together the two video feeds from my patch and my omin-directional antennas in to one much cleaner video.  Happy days.
    I have been working on the handheld unit as well so update on that soon. I was able to get the logging working properly and GPS also tested.  So far- it seems like I should be able to finish it up soon.
    Just need to make a case for the air unit and decide if I want to do live telemetry via LORA radio or just store the data on the SD card on the aircraft.  Lots of options here where I can even link multiple receivers or do more crazy stuff.
    Fist step is to finish the code...
  • Files Added
    Eric Wiiliam06/04/2020 at 18:34 0 comments
    I added the CAD files and links for a 3D printable enclosure to the GitHub repo. This is a larger project box for use with the breadboard testing variant. The final version for proper PCB will come later but some may wish to have theirs on a breadboard so this will probably be handy in the future
    The files are customized from another Thingiverse design you can find in the links/attribution. You can use the website customizer to change the design to suit your design for any changes needed.
  • GPS Finally Working...Again
    Eric Wiiliam06/03/2020 at 01:04 0 comments
    What I thought would be an easy GPS re-integration was anything but. I had this working fine in the past when I originally tested this code as the ResQ-Air version inside my plane but there have now  been changes in the ESP board libraries/software serial (seemingly to support ESP32) which broke all the functionality for me so that serial was impossible.
    Updating the GPS libraries and board defs )added to my repo as well for future ref) finally got it compiling but the pins 3 and 4 dont work directly for the D1 mini and need to be swapped for their true numbering of 0 and 2. Apparently I had forgotten this since last year...
    The BN220 is working at 9600 baud (default it ships with) on the pins discussed. I put 2 example sketches in my GitHub repo so anyone else can test theirs too if they need to troubleshoot without the OLED and SD card.
    Now to integrate all the code together which I have never done before (with OLED).  If push comes to shove I can omit the OLED entirely and just log to SD only or slap on a bluetooth module and just connect that to serial to use your phone or tablet as the interface.  Handy.
    Winning :)
  • Code Uploaded/Updated
    Eric Wiiliam06/02/2020 at 20:05 0 comments
    All current code is now moved to GIT. It's open source now :)
    On the weekend I went out and did some range tests with the YAGI- there were so many people even in my remote area that it just spammed me with MAC addresses.  I good problem to have I suppose :)
    I ran in to some issues with the OLED and found I could NOT make the I2C display work at the same time as writing to the SD card via SPI.  No matter what I tried it seemed to not work. Eventually I guessed that it was a RAM issue and not a strange hardware glitch so I moved over to the lightest display library I could find (instead of the Adafruit one) and it now works!
    I also got some neat comments pointing out that this may work quite well on game preserves to catch/track poachers. I see no reason it wouldn't as long as they are carrying a phone without wifi turned off. I suppose most do.
    Neat idea anyhow.
  • YouTube Playlist Created
    Eric Wiiliam05/31/2020 at 15:09 0 comments
    I have created a dedicated playslist for the ResQ project here:  https://www.youtube.com/playlist?list=PLxyM2a_cfnzifVreG8aKurH-9nNYl8QLr
    All the clever viewers that deduced that all the drone and ESP8266 projects were related- You were right :)  The playlist starts from the beginning of the Nano Talon build and covers it right until the end including the telemetry data so anyone, anywhere should be able to build this EXACT airframe to carry the ResQ if they like.
    Tutorials on the Wemos antenna mod and SD card wiring also included- as you all suspected they are indeed in order so others can make this entire project :)
    Videos and instruction upcoming on the final assembly of the ResQ and the different versions of it (standalone and live data at this time) stay tuned.
  • Hackaday Project is born
    Eric Wiiliam05/31/2020 at 14:48 0 comments
    Well the project has now been underway for >1.5 years so it is time to share it. You will find all the relevant video links and BOM in my GitHub repo for now as I move things over to a user-friendly format here on the Hackaday project. I've been testing the ESP8266 and YAGI antenna system for some time as well as the Nano Talon aircraft for remote use. So far it looks like this project works as I intended.
    It should be possible to detect a lots person in remote areas as long as their cell is turned on and wifi is not disabled. Commercial units are available using the cell signal "pings" but are limited to the exact frequency used by the phone (GSM LTE etc). They are also RIDICULOUSLY expensive >15K USD so no search and rescue or Game Warden organizations could likely ever afford them.  My version costs under $50 USD and can be used by people in the existing manned aircraft or attached to ANY drone or RC aircraft.  Handy.
View all 7 project logs
ris wrote 4 days ago point
My guess is you'd get even better results if you listened for signals on the cell frequencies. The phones may be out of range but they'll still be probing at full power for a cell station.
Eric Wiiliam wrote a day ago point
Surely but that would require a specialty radio that I do not have I'm afraid. Hence 2.4
ris wrote a day ago point
You could do it with a low-end SDR.
