Please see a video of hand shake being tested at Beaumont College, Lancaster, UK here:
Project details can also be found on my website at:
Setup instructions are on my website at:
hand shake set up instructions
The latest hand shake system uses the BBC micro:bit. One microbit is worn on the wrist and a second is connected to a laptop or communications device. When a gesture is made, the motion is detected by the microbit on the wrist. This microbit uses its radio to signal the microbit connected to the laptop. This microbit then triggers an event on the laptop through the USB cable connected to the laptop. The trigger can also be used as switch to control communications software, such as Smartbox’s Grid software. Thanks to Sensory Software for giving me a licence for this software to allow me to test the hardware with it.
Licence
This project and all of the associated files are covered by the GNU General Public License version 3 (https://opensource.org/licenses/GPL-3.0)
matt oppenheim
Eng. Angel Arturo Ramírez
Le Shen
John Boyd
That sounds like an innovative project! Using micro for gesture-based communication is a great way to empower individuals with physical disabilities.
https://www.starbucks-secretmenu.com
This project not only enhances communication but also encourages independence and interaction for those with physical disabilities.
