• Testing TDA1543A and TDA1545A
    andrey.malyshenko07/15/2020 at 20:17 0 comments
    Next to test was 2 classic budget ICs: TDA1543A and TDA1545A. Unfortunately, despite the time spent i failed to make them work properly. I suspect that they could be fakes, since i got them from chinese platform for a price of € 1,6 per 5 pieces, giving € 0,30 a piece. I have no plans to buy them from trusted supplier, since then price leaven no senso of using them in low-budget projects.
    Data format: left justified, stereo output
    Ouput: high-impedance, biased, requires output driver
    Price: ~€0.30 per unit
    So lets call them replicas of TDA154X and see how output  looks like. I've connected both according to original's datasheet, input still the same: mono wav file generated by esp8266 module using ESP8266Audio library modified for LJ format, industry standard 44.1Khz sampling rate.
    TDA1545A, no output filters, 2KHz
    TDA1545A, no output filters, 10KHz
    Input signal is visible, so i guess data format is OK. However waveform is so messed up, i can't be bothered to connect it to amp and speakers.
    TDA1543A, no output filters, any signal
    I failed to make it work really, it looks like input format is wrong, even it is ok for TDA1545, and they suppose to have same input format. So nothing I really could say about that.
    I tried few different ICs, from same seller however, so makes not much sense to expect a difference.
  • Tests of PT8211 IC
    andrey.malyshenko07/14/2020 at 22:16 0 comments
    Next to test is bare naked I2C DAC from unknown to me chinese manufacturer. It is advertized as (not really) direct replacement of TDA1311 DAC ond partially its successors TDA154X series. It requires output driver and i added one using 4558D opamp according to dtasheet application circuit
    Price: ~€0.10-0.20 per unit
    Clearly it is here because the price, and it is not expected to have hifi performance, but rather support low-cost audio driver in projects.
    Here is the setup.
    Only element added to above is output 1uF cap to filter out DC.
    Again, I only have toy oscilloscope, therefore results will be eye measured:)
    Test signal is mono wav file generated by esp8266 module using ESP8266Audio library modified for LJ format, industry standard 44.1Khz sampling rate.
    1KHz on the output, after driver
    2KHz after driver
    10KHz on the output, after driver
    20KHz on the output, after driver
    As you can be seen, already at 10Khz distortions are huge, and 20Khz is a mess. However up till 20Khz there is no fading out of signal, and despite harmonic distortions i expect it to sound quite nice (for the price). As i said before, this is bad candidate for Hi-Fi sound, but very promisiong chip for less demanding audio applications. I keen to see it in action.
  • Tests of PCM5102A module
    andrey.malyshenko07/14/2020 at 20:11 0 comments
    Next to test is another popular module from unknown manufacturer based on PCM5102A chip. It has a bit strange power schematics compared to datasheet, but nevertheless it is one of my favourites in terms of usage in projects
    Data format: I2S, stereo output
    Ouput: medium-impedance, capable to drive headphones
    Price: ~€4 per unit
    Here is the setup. Test circuit is a module itself, since it has built in output filter. It is identical to my setup, apart of R=470 Ohm, C=2n2, giving same 30KHz cutoff frequency
    Test signal is mono wav file generated by esp8266 module using ESP8266Audio library, industry standard 44.1Khz sampling rate.
    1KHz before filter, after filter
    2KHz before filter, after filter
    10KHz before filter, after filter
    20KHz before filter, after filter
    What can be said here. It has relatively clear output even before filter applied. After filter i see no issues even on 20Khz. Curve is clean and properly leveled for every measured frequency.
    To compliment more, I listen one of these modules every day in my home audio setup and I perfectly happy with it. Given it's price, no more to ask really.
  • Tests of MAX98357A module
    andrey.malyshenko07/14/2020 at 19:46 0 comments
    First to test is popular ready-to-use module based on MAX98357A chip.
    Data format: I2S, mono output
    Ouput: 3W D-class amp, low-impedance
    Price: ~€4 per unit, or ~€7 per stage
    Here is the setup and test circuit
    On the output there will be sine tones on following frequiencies: 1K, 2K, 10K, 20K
    Unfortunately i only have toy oscilloscope, therefore results will be eye measured:)
    Amp will be loaded with 10 Ohm resistor and measurment will be done on the output and after first-order low-pass filter set on ~30K cutoff frequency, which would be standard in every DAC's ouput.
    As you can see, output is quite noisy, this is what you expect from low performance D-class amp, even after RC filter line is loaded with noise. Probably you can eliminate it more by adding more ouput filter stages, but since it is already beyond normal out-of-the-box usage of module, i will not do it for now.
    More importantly alteady at 10Khz signal level is ~3V peak-to-peak, compared to ~4V at 1KHz. This is significant drop, most certainly hearable.
    20Khz performance is beyond words. Signal is simply vanished.
