LoRaWAN + BLE for Location Solution
LoRaWAN + Bluetooth Beacon for Location Solution
An indoor area system is created by incorporating cordless interaction, the base station along with inertial navigating positioning, and also various other innovations to acknowledge along with keeping an eye on the set of people as well as likewise things in an indoor area. Typical interior cordless placing modern-day technologies consist of Wi-fi, Bluetooth, infrared, ultra-wideband, RFID, ultrasound, and Zigbee. yet they are not ideal for particular, inexpensive, reduced power as well as long-range indoor location systems.
Based upon brand-new generation BLE placing as well as LoRaWAN -Based developments, we can offer a suitable and additionally cost-effective cordless location treatment for both interiors as well as outdoor usage by incorporating our LoRaWAN-Based FAMILY DOCTOR tracker, BLE probe together with Sign item within the location system.
Based on new generation BLE positioning and loraWAN®-Based technologies, we can provide a perfect and low-cost wireless location solution for both indoor and outdoor use by combining our LoRaWAN®-Based GPS tracker, BLE probe and Beacon product within the location system.
  • 1 × bluetooth beacon Bluetooth beacon likes a smart lighthouse: it repeatedly transmits a single signal that other devices can see. Instead of emitting visible light, though, it broadcasts a radio signal that is made up of a combination of letters and numbers transmitted on a regular interval of approximately 1/10th of a second. A Bluetooth-equipped device like a smartphone can “see” a beacon once it’s in range, much like sailors looking for a lighthouse to know where they are.
  • 1 × LoRaWAN-Based GPS Tracker LoRaWAN®-Based GPS Tracker is based on standard LoRaWAN®-Based protocol for assets tracking, which built-in GPS & 9-Axis Motion Tracking sensor. Ideal to optimize (intra-) logistic process in the field of container- and asset management, warehouse and inventory scenarios, outdoor tracking, theft protection and much more. In a definable interval, LW001-BG automatically reports its identification number, movement and acceleration data as well as the position. Moko also could provide customized service to suit your application scenarios.
  • 1 × LoRaWAN-Based Gateway The gateway has a compact appearance and easy to install on the roof, wall and indoor environment.It can be widely used for smart factory, smart building ,smart office and other IoT system.
  • 1
    Bluetooth Beacon
    For indoor positioning only, combine the Bluetooth Beacon and BLE probe. The BLE probe is placed in a fixed and known position where it will scan the nearby Bluetooth  Beacon and send its MAC address, RSSI and raw data to the server. The Bluetooth  Beacon position can be acquired using the Pythagoras theorem when the three BLE probes receive the same MAC address at the same time.
  • 2
    LoRaWAN
    For both indoor and outdoor positioning, combine the LoRaWAN-Based GPS tracker and BLE probe. The LoRaWAN-Based GPS Tracker supports both BLE and GPS locations. The GPS positioning can be used for outdoor situations. With indoor situations, the LoRaWAN-Based GPS Tracker can serve as a BLE beacon that can be scanned by the nearby BLE probe, which will send the information to the LoRaWAN Gateway server. The LoRaWAN-Based GPS Tracker position can be acquired using the Pythagoras Theorem when the three BLE probes receive the same MAC address at the same time.
View all instructions
