Information in differential line drivers is transmitted using two opposite signals. They send the same electrical signal as two unlike signals, each on a conductor of its own. The conductors can either be a track on a circuit board or wires that are paired together.
HD29051is a differential line driver/ receiver with three state output design. Each device has two drivers/ receivers in a sixteen pin package
Features of HD29051FP
- Built in current limit for short circuit
- Power up/ down protection
- High output current
- Input hysteresis
- In phase input voltage
Replacement Part
SN7534050, SN7534051
Pictorial View
Pictorial view of UTSource HD29051FPis shown below, it is available in sixteen pin FP-16DA package
Pin Description
Pin description and pin diagram of HD29051FP is given below
Pin Number | Pin Name | Description |
1 | R1B | 1st Schmitt trigger inverting input |
2 | R1A | 1st Schmitt trigger non inverting input |
3 | R1Y | 1st Schmitt trigger output |
4 | D1 ENABLE | Data enable first channel |
5 | R2Y | Output of 2nd Schmitt trigger |
6 | R2A | 2nd Schmitt trigger non inverting input |
7 | R2B | 2nd Schmitt trigger inverting input |
8 | GND | Ground |
9 | D2A | Data input second channel |
10 | D2Y | Output Y |
11 | D2Z | Output Z |
12 | D2 ENABLE | Data enable second channel |
13 | D1Z | Output Z |
14 | D1Y | Output Y |
15 | D1A | Data input first channel |
16 | VCC | Power supply |
IC Electrical Characteristics/ Specifications
Some Electrical characteristic of HD29051FP are given below
Parameter | Description | Value |
VCC | Supply voltage | 7 V |
VIN | Input voltage A, B | ± 25 V |
VID | Differential input voltage | ± 25 V |
IO | Output current | 50 mA |
VIE | Enable input voltage | 5.5 V |
VIN | Input voltage | 5.5 V |
VO | Output applied voltage | -1 to 7 V |
TOPR | Operating temperature range | 0 to 70 V |
TSTG | Storage temperature | -65 to 150 C |
Working Principle
Differential signaling is a method for electrically transmitting data using two opposite signals. In this technique the same electrical signal is sent as a differential pair signal. the receiver circuit responds to the difference between two electrical signals. This technique affects the performance of the circuit against the electromagnetic noise.
Applications
Differential line driver/ receiver can be used in following applications
- Balanced audio circuits
- Digital signaling
Noise Cancellation using Differential Receiver in Digital Circuits
A diagram of a representative circuit for differential receivers is shown. Not here due to differential input, input pulse is received with high amplitude and noise is cancelled due to differential effect.
![](https://cdn.hackaday.io/images/6844021594783475473.jpg)
Signal Transmission
Differential line driver/ receiver is used in signal transmission is shown in the circuit below.
How is this a project? More a datasheet and application notes. Inappropriate.
