Xtruder - A Desktop Filament Extruder
The machine uses an extrusion screw to make filament, yarn and small beams out of plastic pellets and flakes
The goal of the project is to develop an cost effective Desktop Extruder which is capable of extruding filament, yarn and small beamsScope of the Project:- Desktop machine with housing- 300&#x20AC; production cost max.- Extrusion Rate 0,5 - 2kg/h - Tolerance +/-0,1mm- Extrusion of standard materials like ABS, PLA etc.- Flakes and Pellets usableThe project management is, like usually, done via MIRO:<a target="_blank" rel="noopener noreferrer" href="https://miro.com/app/board/o9J_km9R-tU=/current">https://miro.com/app/board/o9J_km9R-tU=/current</a> Status:A-Sample: [finished ]f unctional prototypes, usually with limited scope of service and low degree of maturityB-Sample: [on going] basic prototypes with full scope of service and a high level of maturity. They may be created using pilot tools.C-Sample: [not started yet] ully functional sample manufactured with series production tools
Feel Free to join the DevLab_TSA Makerspace Discord-Channel
  • B2 Sample finished - Project Canceled
    DevLab.nrw12/12/2020 at 16:01 0 comments
    Okay guys, the project will be canceled. Even with the 30mm Screw the results have not been satisfying. The extruded volume was too low and I had a lot of problems with molten pellets stucked and baked on the screw. So I don't want to invest no more effort. Instead I will go on with another project and a 'real' extrusion screw. So stay tuned
  • B1 finished, Start of B2 Sample
    DevLab.nrw12/01/2020 at 11:10 0 comments
    The B1 sample is finished. The wiper motor had an overheat defect, therefore a new 250W motor is used. Wich, suprisingly, costs the same. Because of the new motor dimesions the hole machine design needs to be changed, but testings have been promising so far.
  • B-Sample First Testrun
    DevLab.nrw10/01/2020 at 04:46 0 comments
    Finished the mechanical part an made some testruns. Had some problems with stucked pellets and added a second heat band. Also needed to reduce the inner diameter of the nozzle.
    The Problems with burned filament are now gone.
    Will add a second temperature controller and change the gear ratio as well as the hopper design.
  • B-Sample - Mechanic nearly finished
    DevLab.nrw09/22/2020 at 04:46 0 comments
    The 3d print of the Hopper finished. Also assembled Hopper, Motor, Gears and Power supply.
  • Further Work on B-Sample
    DevLab.nrw09/18/2020 at 19:43 0 comments
    Drilled the plates, cutted the threaded rods, tested the ball bearings, assembled the first test-Hopper, cutted the nozzle inlay + thread cutting
  • B-Sample: CAD-Model finished, start of Assembly
    DevLab.nrw09/13/2020 at 12:07 0 comments
    Took a few CAD Sessions but I came up with an usable model. (without housing for the first step) Also began with the mechanical assembly. The Extruder Pipe with flange is ready and I am temporary working on the sheet elements.
  • Finished A-Sample, Start of B-Sample
    DevLab.nrw09/06/2020 at 07:46 0 comments
    Starting with the CAD Work for the B-Sample. The A-Sample will be disassembled and some of the parts will find a place at the B-Version
  • Finished testings of the A-Sample
    DevLab.nrw09/05/2020 at 21:00 0 comments
    Finished all the testings with the A-Sample. Yarn, Filament and smaller beams can be extruded.  For further testings and increased Quality of the extrudes materials, a better mechanical and electrical construction is needed.  So lets move on to the B-Version.
  • Test of the functional Prototype
    DevLab.nrw09/03/2020 at 06:52 0 comments
    The functional Prototype works ! The mechanical construction and the wiring a really poor at the moment. But even this low level machine gives acceptable results. Next step will be some testing if a speed control is needed and if a Arduino 'Motheroboard' is used instead of single controller
View all 9 project logs
