The final product
A Raspberry Pi internet radio receiver, that allow you to browse and play more than 2000 online radio stations using the analog controllers of an old radio.
The original radio device
I found this beautiful radio in a second-hand products website. Invicta model 5426 made in Spain in the 60's
The insides
For this project I used:
- A Raspberry Pi 4 2GB
- 4 Rotary encoders for navigating the map and menus
- An old computer speakers
- 8.9 LCD display
- Wires and some custom 3d printed pieces
The case
The case was in a good condition, all I had to do is clean the controllers and the plastic main piece, and painting a dark brown stripe around it.
I also replace the original cloth with a new one.
The software
I designed a web-based mini operating system in Javascript-Node to control the rotary encoders and move the map.
A server running in the Raspberry PI listens for the rotary's input to control the menus and navigate in the map. All features, including the option of connecting to a new wifi network can be controlled with the rotary encoders, without needing keyboard or mouse!
I used 4 rotary encoders: one for zooming the map, one for X axis movement, one for Y axis movement and one for managing the volume and menu options.
For the maps I used Leaflet js library and a custom map designed based in Vintage Map design from Mapbox
This looks amazing, would really like to make one myself, as far as setting up the server and mini web based operating system I would really appreciate some advice on setup please
