Synthetic hydraulic fluids
A project log for SRAM hydraulic brake o-ring
Swap or replace o-rings
thomasThomas 09/20/2020 at 02:210 Comments
Various available fluids found online that may be appropriate for hydraulics:
Pentosin CHF 11S:
OEM power steering fluid (European):
OEM power steering fluid (Asian):
Prestone European power steering fluid:
FEBI hydraulic fluid M6162:
Synthetic DOT3 (eg lucas oil synthetic):
Advantage of synthetic:
Viscosity index: lower = change more with temperature, higher = change less.
Viscosity: higher = thicker.
Kinematic viscosity: how fast fluid is moving when force applied.
Links:
https://www.pinkbike.com/forum/listcomments/?threadid=140344&pagenum=3
https://forums.mtbr.com/brake-time/mystik-mineral-hydraulic-oil-brakes-1070783.html
https://www.ncbi.nlm.nih.gov/books/NBK304428/ (mineral oils study)
