CPU Monitor Jr
Display Windows CPU and Temp info on a 1602 LCD driven by an ESP32
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
EDIT: This project now has a newer version that uses an Lilygo T-Display S3 - for more info please see: https://hackaday.io/project/192008-pc-monitor-jr-v2
Open source project I put together to display Windows CPU and Temp measurements on a LCD 1602 (or LCD 4002 if needed) with I2C module driven by an ESP32 DOIT Devkit 1 with an optional Real Time Clock module.Quick video of unit in action is here: https://youtu.be/_QJ4vTKItAELonger instructional video is here: https://youtu.be/T0VhOJ6E-TQOpen source (arduino code, windows code, 3d printed enclosure) is here: https://github.com/roblatour/CPUMonitorJr Hope it will be of interest as a model and good use as DIY project for you! website: rlatour.com/cpumonitorjr
