Automatically checks for updates when you start the script, and Downloads and Installs if any update is available so.
[2] Utilises the Power of CPU-Cores :
Can utilise Maximum no. of Cores available.
This means increases the process of cracking of zip passwords by opening different processes on different independent cores.
What this basically does is Split the inputted words from the given WordList and divides them in the no. of Cores Available or Selected and distributes that splitted list among all selected independent cores and work simultaneously ...
