The device presented above in the video represents Marble maze game that is controlled using a smartphone via Bluetooth connection.
This Project was sponsored by NextPCB. You can help support me by checking them out at one of given links:
Only $7 for SMT Order:
https://www.nextpcb.com/?code=Mirko
Reliable Multilayer Boards Manufacturer:
PCB Boards 10pcs for Free:
https://www.nextpcb.com/pcb-quote?act=1&code=Mirko
20% off - PCB Orders:
https://www.nextpcb.com/pcb-quote&code=Mirko
It consist few components:
- Arduino nano microcontroller
- Bluetooth adapter
- and Two 9grams servo motors
The application to be installed on the smartphone is: "Sensoduino" from Hazim Bitar, and the .APK file is given below. Tilt and pan signals from the accelerometer are converted into motion by the corresponding servo motors.
First we need to connect the Bluetooth adapter. Next we need to start the program on the smartphone and select the accelerometer from the given sensors. Now we can start playing. In the continuation of the video is presented the method of making. You can create the maze on one of the online generators, for example at "mazegenerator.net". Finally, the device is made of 3mm PVC board coated with colored wallpaper.
Neat idea. Do you see any issues with latency on the B;luetooth link affecting game play?
