3D printable miniature plotter chassis
Sources files and startting base to build a mini plotter , manual or driven by stepper motors. Using classic 3D/CNC cheap parts.
Public Chat
I started this project because it was so hard to put the SMD PCB Stencils in the right position. I wanted a manual X-Y opensource plotter which would require the minimum of alibaba chinese parts. Most of electronic PCBs are small so I did not want to waste money and the planet to purchase a huge tool. I wanted something we could customize , modify... This basic plotter work was designed in 24 hours using solidworks ( I have the chance to have a licence for this cool software). After I made the tool with only the PCB plotter goald in mind, I realized that it can be modified to build a small 12x12 cm CNC or laser cutter, even a pick and place machine.
I'm postting the sources in the hope we can build a community of people to modify it and expand the possibilities.
- 348.91 kB - 11/08/2020 at 13:30
Download
Download
MorphStencil - cadre-1.STL
Chassis up part
- 108.77 kB - 11/08/2020 at 13:30
Download
- 431.53 kB - 11/08/2020 at 13:30
Download
- 482.89 kB - 11/08/2020 at 13:30
Download
View all 7 files
  • First modification
    pcadic11/11/2020 at 17:43 0 comments
    I had time to build the first 3D printed parts and found a few mistakes.  I corrected the 3D STL FILES under solidworks for the next print.
View all 2 project logs
  • 1
    List of mechanical parts
    You will need to get this list of mechnical parts.
    All screws are 3 mm screxs
View all instructions
tetref wrote 12/20/2020 at 14:03 point
I tried to assemble it in a CAD program and it doesn't fit the holes in KFL08 and one part even collides....
