I wanted to use a single shape PCB to make a sphere for production purposes. I ended up using the https://en.wikipedia.org/wiki/Icosahedron shape with 10 LEDs on each PCB. These were all strung together on a single LED chain using WS2812Bs.
Design decisions:
MCU:
Teensy or ESP32? After a brief search, it looks like Teensy and the ESP32 are both great candidates for this.
The Teensy setup has a nice rj45 breakout board for this application here and the library that goes with it can actually play right from a video file. Out of the box for just under $50 (no LED strips) this seems reasonable.
Having used ESP32s quite a bit in the past (and them being cheaper), I leaned towards this initially. Big benefit of wireless control.
Library:
Top contenders are:
- NeoPixelBus
- FastLED
- OctoWS2811 LED library (teensy only)
LEDs:
The big decision here is to go with prefab'd strips or make something custom (like in the instructable below). The sphere form factor certainly presented a challenge. I ended up testing out a new PCB vendor that could place components for me, and they turned out great.
Whats next?
With wireless updates and a battery, there are a few fun options. I am also considering a larger scale option.
Resources / inspo:
Myles
Moritz v. Sivers
Stanislas Bertrand
davedarko
