Partner_CD7220_significant_fragments.txtThe bit shifting the character pixels to the output port bits.plain - 6.27 kB - 12/04/2020 at 15:00 |
Partner_CD7220-Hi.d52Disassembly of Partner_CD7220-Hi.bind52 - 173.92 kB - 12/04/2020 at 14:58 |
Partner_CD7220-Hi.ctlControl file for guiding the disassemblerctl - 10.96 kB - 12/04/2020 at 14:58 |
Partner_CD7220-Hi.binFirmware containing the driveroctet-stream - 32.00 kB - 12/04/2020 at 14:57 |
Partner_CD7220_Lo_binary_dump_edited.txtFirmware showing the character dataplain - 523.62 kB - 12/04/2020 at 14:56 |
d52v336.zipD52 8051/8052 Disassembler, Version 3.3.6 Jan 2005.Zip Archive - 216.50 kB - 12/04/2020 at 14:49 |
CU20029SCPB-KV90B-09-k1.pdfNoritake's own driver board data sheetAdobe Portable Document Format - 181.16 kB - 12/04/2020 at 14:46 |
CU20029SCPB-KV90B-07.pdfNoritake's own driver board data sheetAdobe Portable Document Format - 119.68 kB - 12/04/2020 at 14:46 |
0-209-cu20029ecpb-w1j.pdfCU2002 bare glass module data sheetAdobe Portable Document Format - 260.49 kB - 12/04/2020 at 14:45 |
CD7220_Manual.pdfManual with fully documented command setAdobe Portable Document Format - 479.68 kB - 12/04/2020 at 14:32 |
