DIY RGB Tube Lights
RGB Tube Lights made using Arduino Nano and WS2812B LEDs.
DIY RGB Tube light is a multi functional tube light which can be used in photography, light painting photography, film making, gaming, as a VU meter and more. The tube light can be controlled by Prismatik  software or by a push button. These tub lights are made using a Arduino Nano and WS2812B LED strip.
RGB Tube Code&Software.zip
x-zip-compressed - 9.17 MB - 12/16/2020 at 12:36
Download
Button_Tube.zip
x-zip-compressed - 347.60 kB - 12/16/2020 at 12:35
Download
  • 1 × Arduino Nano https://amzn.to/3r2x4sY
  • 2 × WS2812B LED Strip https://amzn.to/2Kwe70O
  • 2 × White Tube Lights Or Aluminum Light Fittings with Diffuser https://amzn.to/38fF6Gu Or https://amzn.to/3ra3d1Z
  • 1 × 5V 5A Power Supply https://amzn.to/3nqCvQi
  • 1 × Push Button https://amzn.to/3mpNEPK
View all 7 components
  • 1
    Step 1:
    • Disassemble the tube light by removing end caps , separating diffuser and removing whites LED strip from the tube.
  • 2
    Step 2:
    • Make all the connections as shown in circuit diagram.
  • 3
    Step 3:
    • Put all the electronics in the tube , put back the end caps and seal the diffuser using clear tape.
View all 8 instructions
