Home made light Saber
It is a home mad light Saber using a 3d printing hilt and led torch and perspecs tube
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
The hilt is a Darth Vader based design with some personal changes. it was 3d printed and then painted. The light source is a simple led torch with a variable light angle. The tip was machined out of perspecs and the blade is a perspects tube. I can change the light source color by using different color lenses that go between the torch and blade.
