Universal PCB Enclosure
A universal enclosure designed for quick deployment
Simply edit the DIMENSIONS file with relevant PCB variables and rebuild the SOLIDWORKS assembly. "LENGTH"= 3.7in 'longest of two dimensions of PCB "WIDTH"= 2.4in 'shortest of two dimensions of PCB "HOLE_DIA"= 0.1in 'mounting hole diameter "HOLE_DIST"= .1375069in 'distance to mount hole centerline from edge of PCB "PCB_THICK"= 0.063in 'nominal thickness of PCB, usually 1.6mm "TOP_CLEAR"= 1in 'Clearance above top of PCB, tallest component plus desired clearance "BOTTOM_CLEAR"= 4mm 'Clearance below bottom of PCB, minimum 4mm
Credit to Adafruit for initial design => https://learn.adafruit.com/permaproto-feather-case
Universal_case_assembly.SLDASM
sldasm - 127.10 kB - 01/18/2021 at 16:25
Download
Universal_case_base.SLDPRT
sldprt - 222.23 kB - 01/18/2021 at 16:25
Download
Universal_case_lid.SLDPRT
sldprt - 149.89 kB - 01/18/2021 at 16:25
Download
Universal_case_sides.SLDPRT
sldprt - 114.68 kB - 01/18/2021 at 16:25
Download
DIMENSIONS.txt
plain - 454.00 bytes - 01/18/2021 at 16:25
Download
View all 6 files
  • 1
    Step 1
    This directory contains the necessary components to build a custom PCB enclosure
    Update ~/DIMENSIONS with correct equations for your PCB
    Rebuild ~/Universal_case_assembly
    export the three components as .STL
    Import and slice the .STL components
    Print and enjoy!
View all instructions
danielcanaday wrote 01/07/2021 at 20:34 point
If there is a demand for it I will attempt to port this to other CAD clients.
