lightDomeSpiky.stl100 gram, 6 inch radius variant! It's called HACKaday! This is a really bad, basically hacked together 3D model of a low material variant which requires fiddling with cura parameters, I changed the line width to 0.3mm and the slicing tolerance to "middle" but was able to get the LED's in by pushing a little harder. Recommended for overhead lights where you want to work on something looking through a microscope and need room to stick your hands in.Standard Tesselated Geometry - 36.53 MB - 02/12/2021 at 16:13 |
CE3_lightDome.gcode.gz300 grams, not recommended. The GNU Zip (gzip) compressed G-code file for the Nocticron version of the dome. Sliced with settings optimized for smooth fit of the 5mm LED's for a Creality Ender 3 V2. Printed and verified to fit well.x-gzip - 24.50 MB - 02/08/2021 at 03:02 |
lightDome-Nocticron.stl300 gram, not recommended for environmental reasons Modified model that will theoretically fit a Nocticron lens.Standard Tesselated Geometry - 15.59 MB - 02/06/2021 at 16:50 |
lightDome.stlThe STL file needed to print the dome. Uses 300g of filament depending on the slicing. I'm testing a low material variant, but for the sake of longevity, just use the extra $4 of filament. The new 100g variant works if sliced right.Standard Tesselated Geometry - 14.85 MB - 02/06/2021 at 09:44 |
