Hackaday.io Hackaday.io
Sign up Log in
Zwift Indoor Bike Gradient Simulator
This is my homemade version of the Wahoo Kickr Climb
pointlessly-usefulPointlessly Useful
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.2k views
3 comments
10 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 3
View Gallery
1.2k
3
10
7
Team (1)
  • pointlessly-usefulPointlessly Useful
Join this project's team
hardware
completed project
This project was created on 02/15/2021 and last updated 5 years ago.
Description
My indoor bike gradient simulator is inspired by the Wahoo kickr climb but costs about 1/4 of the price to build. It utilizes a cheap linear actuator in order to move the bike up and down. The actuator is controlled with a raspberry pi zero with a motor controller, the pi is running a simple web server that can be sent the gradient target for the simulator to match. The aim for the simulator was that it could interface with Zwift to read the gradient in the game, to do this I am running a python script that takes screenshots of the game and uses OCR to read the current gradient.
Details
Log In/Sign up to comment
Sign up with Github
Sign up with X
OR
Baird Bankovic wrote 11/18/2021 at 04:25 • point
I would love to build this over Christmas break, do you mind sharing your source code? Also, I would like to make some improvements to reduce the noise, along with adding 'support' for Wahoo SYTM. Also, what is the purpose of the web server? Just to communicate between Zwift on the computer and the PiZero? If so, I would love to add this little board to the project which converts the HDMI output from a computer to CSI-2 that the camera input is on the PI. Then, this is a completely fool proof method (just don't update Zwift :) )
Anyway, if you do not post source code and what not, I will build something similar around Christmas. I'll keep you posted if I do :}
Cheers
periquitaun wrote 10/15/2021 at 19:52 • point
I have a similar project. I obtain the gradient from the Zwift log file in a C# program. This have a 4 seconds delay, Your solution is better. Could you share your Phyton software?. Thanks in advance.
khawks wrote 10/13/2021 at 15:15 • point
I like the hardware in your project.
Any chance you will post the code on github?
Thank You!
If you're working on a weekend project with a Raspberry Pi computer, these Raspberry Pi command line instructions will likely save you time.
Project Owner Contributor
Quick Guide for Raspberry Pi Users: Raspberry Pi T
undefined
16 player JS Joust and a ton of other features all running on a Raspberry Pi.
Raspberry Pi JS Joust
aaron-angertAaron Angert
Play your favorite PC games on Raspberry Pi with ExaGear Desktop
Raspberry Pi Gaming Emulator
dmitryDmitry
Different ways of playing your favorite games on Raspberry Pi any other ARM devices
Gaming on Raspberry Pi or any other ARMs
dmitryDmitry
Going up?
© 2025 Hackaday
Yes, delete it Cancel
You are about to report the project "Zwift Indoor Bike Gradient Simulator", please tell us the reason.
Send message
Remove Member
