New BEC and blades shaped
06/02/2021 at 16:48 • 0 commentsJust when rotor testing was ramping up, the 5v regulator for servos and flight controller decided to die. But a new one is now installed and the blades have been shaped for better aerodynamics. Rotor testing and tuning can now commence as we push toward a test hop.
Lots of progress...
05/25/2021 at 03:34 • 0 commentsIt's been a while since the last update... Final exams and projects ramped up--but at least now I've secured my Master's degree in rotorcraft!
The fuselage is just foamboard hot glued to the main fuselage mounting plate. I've got my flight controller (dRehmFlight VTOL: https://hackaday.io/project/174768-drehmflight-vtol) buried in there along with some 30a ESCs, 10a BEC for the huge servos, and a 1500mah 4s battery. The blades aren't done yet, but I was so excited to see this thing fully assembled. They still need beveling, taping, and balancing.
Next up is taking care of the blades, then other small issues like belt tension, then we'll try for a flight. Even if it doesn't work (I give it ~60% chance), I think I'm still going to give it a really nice paint job. Super cool having a 1:1 scale Ingenuity sitting in the living room!
I think I'll call this one "Scrappy", Ingenuity's little Earthling brother.
Congrats Ingenuity Team!
04/19/2021 at 18:01 • 0 commentsThe (real) Mars helicopter completed it's first successful flight today! Now to get this one flying down here on Earth
![The helicopter's navigation camera captured a view of the Ingenuity's shadow on the Martian surface during its first flight.]()
Swashplate and linkages assembled
04/19/2021 at 03:34 • 0 commentsHopefully we see a flight (of the real Ingenuity) tomorrow morning! I spent some time tonight getting the swashplate all setup and the 'blade grips' mounted to the main shafts. When I can find the time, the next step is hooking up electronics to see the proper swashplate actuation while the blades are rotating, and to make sure there's not too much resistance on the geared down motors. It feels fairly easy to rotate by hand, so fingers crossed it stays that way...
Fuselage baseplate fitted with parts
04/16/2021 at 03:31 • 0 commentsThe fuselage consists of a single 3D printed mounting plate where the servos and motor directly mount to. I've got them all installed and the rotorshafts running through to the inside where they're driven by a belt and pulley. As you can see, we have thoroughly departed from the original Ingenuity design at this point:
Rods cut and the skeleton is taking shape...
04/16/2021 at 01:01 • 0 commentsGot to the shop to cut some shafts and size them up for the bearings. The skeleton is taking shape! Next up is motors installation and testing the drivetrain before securing parts (epoxy) to the shafts... Then blades...then electronics. Stay tuned.
Nick Rehm
