Anteneh Jerrycan made from car tires/ inner tube
03/03/2025 at 11:14 • 0 commentsAnteneh Jerrycan made from car tires/ inner tube... I had an inspiration to manufacture my Jerrycan from used car tires creating circular economy for agriculture and livestock water fetching. The rubber insulates the water from high temperatures and keeps it cleaner from algae and more environmentally-friendly than other trough materials like plastic.
Anteneh Life saver
01/23/2025 at 14:20 • 0 commentsAnteneh Life saver... Truth and Anteneh Jerrycan are similar in a same way oil floats no matter how much water there is.
Cleaning the inner surface of Anteneh Jerrycan from fungi
12/17/2024 at 22:56 • 0 commentsOne of the main question I have gotten during my presentation for the World Bank Youth Innovation Challenge Pitch
was how do we clean the inner surface of the Anteneh Jerrycan from fungi because rural areas collect water from rivers and river water accumulate fungi easily. My first solution was manufacturing the Jerrycan in Design for Assembly (DFA) to disassemble when cleaning is needed on the hands of customers but this is a challenge to do in mass production on blow molding. But now I figured it out. I am going to clean it using a magnet system.
As seen in the above picture we install a very light metallic ring (red) that have outer diameter equal with inner diameter of the Anteneh jerrycan pipe (black). Between the two surface there can be a cleaning sponge like material to minimize the friction and act as a pipe surface cleaning material. By using a ring like magnet or half ring like magnet (depending on strength of the magnet and surface friction between the ring and pipe) we can pull the cleaning ring by moving the magnet which will clean the inner surface of the pipe as seen in the window cleaning system below.
Product diversification
03/02/2024 at 13:34 • 0 comments![]()
Competition study
01/05/2024 at 09:36 • 0 comments![]()
While studying my competition I greatly improved their design… there are few rolling jerrycans like waterwheel and Q Drum having a cylindrical shape container rolling on ground. Rolling water on ground requires roll-able ground and rough terrain, muddy ground and steep slop would make the product unable to use but if you can roll it make the shape SPHERE is ideal because sphere have one point contact with the ground reducing the surface friction which result in lower force needed to push the jerry can.
Prototype testing
12/04/2021 at 15:46 • 0 comments -
Project submission for impact africa program
04/05/2021 at 08:40 • 0 commentsMy projects are submitted to the impact africa... Looking forward for the evaluation report.
Numerical and structural analysis
04/04/2021 at 09:48 • 0 commentsPlease see the project details for the numerical and structural analysis of the product.
This will prove my claims undeniably with numbers.
Thank you.
First order
04/02/2021 at 08:22 • 0 commentsI am very excited to announce that I have received the first oversea order from a very interesting client who is willing to pay in full before shipment.
Project publication on the hackaday newsletter
03/31/2021 at 20:01 • 0 commentsWhat a great moments for ANTENEH'S JERRY CAN... another publication on the hackaday newsletter... If you subscription check out your promotion inbox.
Anteneh Gashaw
