test-relay.pyCompletely optional script I used to test my 8 channel relay when it was hooked up. It just turns them all on one at a time then all off one at a timeplain - 2.54 kB - 03/18/2021 at 05:00 |
run.pyMain File to run the Twitch checking while loopplain - 3.92 kB - 03/18/2021 at 04:42 |
config.pyConfig fileplain - 1.63 kB - 03/18/2021 at 04:42 |
helper.pyExtra functions including Twitch APIs and Relay controlsplain - 11.87 kB - 03/18/2021 at 04:42 |
Bottom Base.stlBottom Base Cap for 3D PrintingStandard Tesselated Geometry - 98.32 kB - 03/18/2021 at 04:39 |
Top Base.stlTop Base Cap for 3D PrintingStandard Tesselated Geometry - 98.32 kB - 03/18/2021 at 04:39 |
Back Cover Export.dxfRear cover to be cut in 3mm (preferably not clear) acrylicAutoCAD DXF - 3.71 kB - 03/18/2021 at 04:39 |
Inner Shelf Export.dxfInner shelf for electronics mounting to be cut in 3mm acrylicAutoCAD DXF - 5.17 kB - 03/18/2021 at 04:39 |
Rear Cover Export.dxfBack Cover (where the ports of the pi are) to be cut in 3mm acrylic and then labelled to identify the OTG and PWR USB ports on a Pi Zero easilyAutoCAD DXF - 6.05 kB - 03/18/2021 at 04:39 |
Top Cover Export.dxfThe 'front' or clear side of the relay case to be cut in 3mm acrylic. A logo can also be etched onto this sideAutoCAD DXF - 7.65 kB - 03/18/2021 at 04:39 |
