Freeform circuit weather display.
A freeform circuit that shows the weather
weather_sculpture_export.inocode for the sculptureino - 6.30 kB - 04/15/2021 at 20:30 |
Graphics Interchange Format - 12.71 MB - 04/16/2021 at 01:01 |
JPEG Image - 1.43 MB - 04/16/2021 at 01:06 |
JPEG Image - 1.70 MB - 04/16/2021 at 01:06 |
JPEG Image - 1.37 MB - 04/16/2021 at 01:06 |
I put the LEDs in the mold and soldered the ground together, then added positive rails for each color LED. Then I took it out of the mold and soldered it to the circuit board.
I also had to fix a couple of problems with my code (the pinout for the NodeMCU is confusing...)
Last, I painted over one of the on-board LEDs so that it wouldn't be so bright and distracting.
This was a fun little project that helped me to learn about how to use WiFi with Arduino boards.
Hope you liked my idea!
I set up an Adafruit IO feed and connected it to Weather Underground through IFTTT to send the weather every morning at 6:00 AM.
I connected the circuit to the internet and tested it with three LEDs to show basic weather (white=cloudy, yellow=sunny, blue=showers/rainy). I also 3D printed a mold/jig to hold the LEDs while soldering.
Very creative! Nicely done.
