Flower Infinity Mirror
infinity mirror in flower shape to have colorful flowers all year round
0 followers
Roses are red, violets are blue. Laser cutters cut mirrors, I know that for a fact! In addition to common materials like wood and acrylic, a laser cutter can also cut shapes from mirrors. I used advantage of this for the following project.
  • 1 × 40cm WS2812b strip with ~13 LEDs and adhesive backside
  • 1 × 1,5m cable 3 wire
  • 1 × microcontroller (Wemos D1 mini)
  • 1 × acryl 15x15cm, 1mm thick
  • 1 × darkening foil/dazzle strip 15x15cm
View all 9 components
  • 1
    Soldering
  • 2
    The assemble
    For the semi-transparent mirror (black), stick the darkening foil onto the acrylic sheet. Then cut out the same flower shape from the semi-transparent mirror and the normal mirror. Then cut out the frame in the shape of flowers from wood.
    Apply wood glue to the edge of the normal mirror and place it in one of the wooden flower frames without a cutout. This completes the bottom layer. On top of this, glue another flower frame without a cutout. Three layers with a cutout follow. Make sure that the cutout is on top of each other. After that, another wooden frame without a cutout follows. Now apply wood glue to the edge of the semi-transparent mirror and attach it to the last wooden frame that is left.
    Now glue the LED strip to the inside of the flower frame and optionally stabilize the solder joint between cable and LED strip with 2-component glue. Now the semi-transparent mirror can be glued on top.
  • 3
    Programming
    For programming I have adapted the "strandtest" example of the NeoPixel library so that the rainbow function is called there.
View all 3 instructions
